AX760 - 8 Pin PCI-e Pinout
chanberg
Wondering if anyone knows where the 12v and ground leads are on the 8pin PCIE connector... I don't have the PSU with me so i can't check, But my AX1200 has the 12v loads on the top and ground wires on the bottom row ( Looking at the PSU dead on - modular ports vantage point, CLIP on top - top 4 pins are 12v and bottom 4 pins are ground) But the AXi series are all opposite.... with 12v on bottom and ground wires on top.
This is inquiry on AX760 (NOT AX760i btw)
thanks
Danny
Let me rephrase... I understand that the cables have to be a certain standard to work with all components, but the pinouts on the PSU are all different depending on brands... This is why brands all say to use their cables, because they probably crossover in a certain way to make them standard... I am making my own cables, which is why i was wondering if anyone had an idea of the pinout diagram for a AX760...
thanks for the replies!
