V Vandrak Aparat Honorable Jan 22, 2014 14 0 10,510 Feb 2, 2014 #1 will ax860i psu power all these components? intel core i7 4770k, asus gtx 780, 3 ssds 2hdds and 16gb ram ?
Solution Tradesman1 Feb 2, 2014 For a single 780 and your rig you only need a good 600 (with about 42 AMPs on the 12 volt rail), the Corsair you have picked out could carry 2 780s
tiny voices Titan Sep 6, 2012 34,175 5 99,965 Feb 2, 2014 #2 Yes it is more than enough. Overkill even. A 650w PSU would be plenty. Upvote 0 Downvote
V Vandrak Aparat Honorable Jan 22, 2014 14 0 10,510 Feb 2, 2014 #3 will the 860i support gtx 780 2-way sli too ? Upvote 0 Downvote
tiny voices Titan Sep 6, 2012 34,175 5 99,965 Feb 2, 2014 #4 Yes easily. A 750w PSU would support that. Upvote 0 Downvote
Tradesman1 Legenda in Aeternum Jun 5, 2013 67,881 41 126,960 Feb 2, 2014 Solution #5 For a single 780 and your rig you only need a good 600 (with about 42 AMPs on the 12 volt rail), the Corsair you have picked out could carry 2 780s Upvote 0 Downvote Solution
