Question B-Die 3200mhz CL14 Overclockable to CL12 and with what settings?
Urppana
Commendable
Aug 2, 2019
5
Yeah So I have FlareX 3200mhz CL14 2x8gb. I'm wondering if Im able to do CL12. Going up in speeds isnt possible due to my mobo limiting me to 3200MHZ. Ryzen 2700x. Also is it possible to keep it CL12 24/7?
Every memory stick will overclock differently. Only way to find out what will work is to try and see. There should be plenty of Ryzen overclocking guide (including memory overclocking) out there if you do a google search, they should help out with what voltages/settings you can try tweaking when you OC.
