B350 Gaming pro carbon led control
Oct 19, 2018
15
Hello,
I have an MSI B350 Gaming pro carbon in which i have connect an rgb fun to the led header on it.
However when i change the lights with the gaming app (mobo and header change as one, no seperate option), while the mobo takes the correct light, the fan takes a random one, the same happened with a led strip i connected to that header.
Is there a way to change the color of the header seperately or at least make them have the same one?
both the fans and the rgb strip are deepcool, more specific the deepcool RF 120. they are connected in the right order (cant connect them otherwise cause the header is 4-pin and the left on is the voltage pin)
https://ibb.co/hRgfXvK
In the second picture there is the difference between the mobo and the fan and the gaming app that only allows me to control the first one (regardless if it changes the color to both of them)
https://ibb.co/S7fNJkW
