B350 Tomahawk - 3200(OC) Memory Speed?
Jul 18, 2018
Hello, I need to know what the OC beside different supported memory speeds for motherboard specs mean. I know OC means overclock, but I want to get a 3200mhz kit on the B350 Tomahawk, but when I read over the specs, it said 3200(OC), does that mean I have to overclock a RAM set to 3200mhz for it to actually run at that speed, or does it mean it supports 3200mhz and is capable of overclocking RAM to that speed? Or is it something different? Please let me know. Thanks!
Yes, you're going to have to overclock the ram. In essence anything above DDR4-2133/2400MHz is an overclock. You can actually go into BIOS(motherboard) and manually input the timings, frequency and the voltage to your ram kit. After a subsequent reboot, it'll take effect.
The board supports ram that are spec'd higher than JEDEC.
I'd advice on updating your motherboard BIOS with one stick of ram.When that's done go in dual channel, with two sticks of ram and then manually input the numbers in BIOS.
so if I were to buy a 2x8GB DDR4 3200, it would run at 3200mhz, right?
Your chances of it working successfully with the latest BIOS is much better. But you have to keep in mind that 3200 is an overclock for both RAM and the processor, which has the memory controller. That means you're also dependent on your processor being capable. The newest Tomahawk BIOS opens up many timing options to help you get it to work. People are reporting much greater success getting their kits to 3200, but you may have to use some of those tweaking options to do it.
All the 3200 specified on the kit package means is the DIMM MFR selected RAM chips with optimal performance characteristics to pass a test on their equipment.
I'd not buy a 3200 DIMM kit unless my vendor will refund or exchange it if I can't get it to work in my system.
these are my soon to be specs
https://ca.pcpartpicker.com/list/Q49yxG
can you let me know if my system will support 3200mhz?
To clarify: 3200 ram speed is an overclock to the CPU only for its memory controller. The R5-1600 in your PCPartPick has a rated CPU core base clock speed of 3200Mhz but it's rated maximum supported memory is 2666. That's why running 3200 memory, even if rated 3200 by the mfr, would be an overclock to the CPU.
