B350 Usb 3.0 driver problem win 10
Ztdutxjgxgtu
Respectable
Nov 30, 2016
632
Need help here
I have asus B350 plus and ryzen 1700
Reinstalled windows and drivers from asus and amd web
Still usb 3.0 ports x4 cant detect 3.0 devices(device works fine with usb2.0 ,3.1and port can read usb 2.0)
Didnt have this problem a year ago
Also tried to load amd old drivers but fail in blue screen, forced to reinstall win...
Used some free driver detect ,and it says usb3.0 psp hub not install
Any ideals? Or good driver update programs suggestions?
If you haven't then try manually installing the USB drivers
Download the Asmedia USB 3.1 Driver form Asus support site
https://www.asus.com/us/Motherboards/PRIME-B350-PLUS/HelpDesk_Download/
Unzip the downloaded file.
Go to the Device Manager and right click the USB3.X controller and select 'Update driver'
Select 'Browse my computer for driver software', click on 'Let me pick from a list of device drivers on my computer' and Click the 'Have disk' button.
Browse the folder with the drivers you previously downloaded and unzipped (Driver_Win10 folder) and then select one of the Asmedia '.inf' driver file
Click Open and Next and follow installation prompts to install USB drivers.
Tried asus driver with no luck.
Setup file error: The asmedia USB controller was not found
Manually: tried many combination with update files,...failed ,or no change
Update new symtom when plug in usb3.0 drive or stick
Stuck on bios , no post
It is only working on ports 3.1 and 3.0 under lan port, not working on separate 3.0 on board.
Sometime usb power surge error pops up continuously, i know i can turn it off
Device show up for a while only in device and printer then dissapear with disconnect sound, so it should be driver /windows issue. But why was it stuck on bios? No clue
