T theddr4h8r Dec 7, 2018 12 0 10 Dec 11, 2018 #1 Hi im going to buy a Ryzen 5 2200g and this mobo.The real problem is .... this mobo only supports hdmi/dvi ports . I have a vga monitor and i want to know : can i use a vga to hdmi active adapter to make it work with my vga monitor?
alexoiu Titan Nov 1, 2012 39,817 250 126,990 Dec 12, 2018 #2 Hi, HDMI to VGA converters, not VGA to HDMI. They are not similar. Upvote 0 Downvote
T theddr4h8r Dec 7, 2018 12 0 10 Dec 12, 2018 #3 but it will work? (the hdmi to vga converter) Upvote 0 Downvote
alexoiu Titan Nov 1, 2012 39,817 250 126,990 Dec 12, 2018 Solution #4 Yes, it should work. When selecting one, check the reviews. Upvote 0 Downvote Solution
O ohiou_grad_2006 Splendid Dec 3, 2011 3,551 10 24,115 Dec 12, 2018 #7 Just watch, hdmi carries audio. You may have to disable the HDMI audio or set your audio chip on the board as default. Upvote 0 Downvote
