The Issue: My PC of about 3 years (working perfectly since it was built) was getting dusty so I decided to clean it out with an electric air duster (that should be safe with electronics). Aside from cleaning fans (made sure to hold them down while blowing), I also removed my cooler and reapplied thermal paste.
However, after putting the machine back together, I get no USB or video output, but RGB and fans turn on. System spins for about ~28 seconds and then bootloops indefinitely.
At this point, I am unsure what component is causing the issue and how to fix it. I think that it could most likely be an issue with the motherboard.
What I've Tried:
-Taking out CMOS battery and resetting
-Removing RAM and/or GPU, same issue (does this mean I can rule out GPU and RAM being an issue?)
-Reinstalling the cooler and reapplying thermal paste
-Unplugging and replugging all motherboard connectors
-Unplugging 8 pin CPU connector (this resolves the bootlooping, but causes nothing else to work)
Specs:
CPU: Ryzen 5 1600AF
GPU: Asus 1650 Super
RAM: 2x 8gb 3200 mhz XPG
Motherboard: Asrock B450M Pro4
Case: Coolermaster MB311L
Power Supply: EVGA 600 BA (non-modular)
Storage: Two m.2 drives, one SATA ssd, one hard drive
Does anyone know what could be the issue here?
What I've Tried:
Specs:
CPU: Ryzen 5 1600AF
