List the full specs of your PC
ASUS B450M K
16 GB DDR4 2400Mhz
Corsair VS450 PSU
GTX 1050ti which i havent put in yet
What CPU do you have? If you have a 3rd Gen Ryzen your mobo may not have an updated BIOS. If that's the case then you need to either borrow a 1st or 2nd Gen Ryzen CPU, take it to a computer shop, or send away for a free loaner CPU from AMD https://www.amd.com/en/support/kb/faq/pa-100 inorder to update the BIOS.
If you have any other Ryzen besides a G (2200G, 3200G etc) you must have a graphics card installed since Ryzens do not have integrated graphics.
I would also strongly suggest you return the RAM if possible and get 3200mhz or faster RAM such as this https://pcpartpicker.com/product/jB...-2-x-8-gb-ddr4-3600-memory-f4-3600c16d-16gvkc
Check my other comment, and i bought this from amazon so i assume that the cpu and ram are already compatabile
You never listed the actual CPU you have. You only listed the Mobo, RAM, Power Supply and Graphics card.
The RAM is probably compatible but Ryzen take a significant performance hit with slower speed RAM, 2x8GB 3200mhz or faster is recommend for all Ryzens.
The cpu, ram amd mboard all came pre assembled in the box.You never listed the actual CPU you have. You only listed the Mobo, RAM, Power Supply and Graphics card.
Nothings worked. Im so fustrated i might have to take it back or get a new caseYou need to install the 1050ti in order to get a video output, so start by doing that (along with any PSU power cables the card may need, some are powered by the PCIe slot only, some require a 6 pin). You also must have your monitor plugged into the 1050ti video output and not the motherboards video output.
Make sure the RAM is firmly seated in the DIMM slots, they could have come lose in shipping.
Make sure the 24 PIN ATX connector and 8 pin CPU ETX connectors are fully inserted. Page 1-1 and 1-2 of you manual will show you where those are.
https://www.asus.com/Motherboards/PRIME-B450M-K/HelpDesk_Manual/
This is also where it will show you the correct hookups for all other USB, front panel IO etc.
If those fail try and boot with 1 RAM stick at a time in the A1 slot, its possible 1 stick of RAM is faulty.
Video -The GTX 1050ti must be installed and connected to your display. Can you confirm that you have done this?
Video -The case wouldn't affect the ability of the computer to boot unless you have the case power/reset button hooked up incorrectly to the mobo.
Where is this orange light on the mobo, can you take video of it and link it here? I believe the orange light is just a standby and power on indicator.
My manual doesnt say which pins are the power switch ones so i might take a whileYeah the light is nothing. It looks like there is an issue with the power button on the fornt IO, either the wiring is messed up on the motherboard or the button itself is faulty.
Remove the front IO button wiring from the mobo and try and jump the power with a screwdriver
View: https://www.youtube.com/watch?v=FuPZlliGqBw
You mad man, you did it LOL. It booter up thanks so much. But what does this mean? My power button is broken?Yeah the light is nothing. It looks like there is an issue with the power button on the fornt IO, either the wiring is messed up on the motherboard or the button itself is faulty.
Alright thanks. Im going to try and fix the wiring but if anything ill get a new case. Thanks for the help.Or you had it wired wrong.
If you do want a nice case for your new parts then here a few well priced good ones.
https://pcpartpicker.com/product/cr...300a-mesh-atx-mid-tower-case-ph-ec300atg_bk01
https://pcpartpicker.com/product/JwVBD3/corsair-case-cc9011075ww
https://pcpartpicker.com/product/bFkwrH/corsair-spec-04-blackgray-atx-mid-tower-case-cc-9011109-ww
https://pcpartpicker.com/product/tj...-blackwhite-atx-mid-tower-case-ph-ec300ptg_bw
