Hi guys,
thank you first of all for this active forum.
I just build a new computer for myself and I have the following components installed:
View: https://imgur.com/a/KaRKdQp
I know would like to have the RAM running at 2933Mhz and not at the stock 2133Mhz. Obviously, I have updated the Bios to the last version. To do this I have tried the following:
- Using A-XMP Profiles 1 and 2 but the computer didn't POST. (even with adjusted voltages as per below)
- Manually entering DRAM Frequency while adjusting DRAM VOltage to 1,36V and CPU NB/SOC Voltage in OVERRIDE MODE to 1,15V
- Using Memtest86 to check the RAM which came back without an error
In all tries the result was the following: the preferences in the UEFI were reset to stock and the computer posted in the stock preference after a failed try.
I really hope that somebody has an idea what is going on or what I'm missing.. Do I need to OC my CPU beforehand?!?
Thanks and have a good Sunday
