[SOLVED] B550 Vision D Vs. X570 Aorus Master
Sep 7, 2020
37
I came across this B550 Vision D Mobo, It suits the theme which i'm going for...but will it be able to handle the 5950X??
Or should I stick with X570 Aorus Master??
is there any X570 Mobos in White??
Don't know about white x570 MBs but I would recommend it for 5950x although it should work on a good b550 MB but possibly with some restrictions. x570 MBs have in average some 33% better VRM than b550s giving you more leeway power wise. Also much better equipped.
