3 weeks ago I assembled a pc with the following components (before I only used intel)
ryzen 5 3600
gigabyte b550m ds3h
cooler master hyper 212 evo v2
the fan curve of my cpu is
21º - 48%
35º - 52%
50º - 62%
62º -72 %
83º -100%
when I open the browser what happens is that the temperature spike in the processor goes from 40º to 60º and in a second starts a little vibration, but then when the cpu temperature went down, it started to vibrate too much, so much that even my keyboard vibrated.
I borrowed a cooler master hyper 212 black edition to test it and had a similar result with the EVO V2, the Silencio FP120 fan also vibrated a bit when rpm's went up and down although less than the Sickeflow 120 on the EVO V2.
I bought a premiun fan Noctua nf A12x25 pwm but the result is the same when I open the browser or any common program ,the fan vibrates ,you can see how it vibrates on the heat sink and it is felt on my desktop , I never had a similar problem when I used intel.
the heatsink is correctly mounted and tightly adjusted.
other details that when I adjust the fan curve in the bios ,sometimes smartfan change my SYS1 and SYS2 settings.
I am worried that smartfan5 is defective, even on my previous intel motherboards the curves were more aggressive and never my cpufan vibrated.
and I'm worried that those vibrations can damage the fan motor.
is this normal in computers with ryzen processors or is it a problem with the motherboard?
and if the motherboard is the problem i could process the warranty?
my problem looks like the one in this video:
streamable.com/iz78g
ryzen 5 3600
gigabyte b550m ds3h
21º - 48%
35º - 52%
50º - 62%
62º -72 %
83º -100%
