Archived from groups: microsoft.public.windowsxp.general,comp.sys.ibm.pc.hardware.storage,alt.backup-software,alt.os.windows-xp (More info?)
I would like to back up my whole Win XP system to an external hard
drive and would like some recommendations as to what software I should
use?
...ie is the Backup that comes with XP Pro ok? How would I restore XP
in the event of a failure? Does it do open files etc?
....is there a single bit of software I can buy that will just dump the
whole HD to the external HD and then provide a simple way of restoring
all of this data to a new HD (in the event of an HD failure) or to a
whole new system (in the event of my laptop being stolen)
Are there any XP funnies I should be aware of? Will it complain that
Im restoring to a different type of disk? - presumably if its a whole
new laptop then I will hit problems?
Should I be doing anything else like creating a bootable disk or
something?
The XP Pro CD I have is "Only to be distributed with a new PC" - does
this mean I couldnt restore it to another PC?
Thanks for any help
David Bevan
http://www.davidbevan.co.uk
use?
something?
Thanks for any help
David Bevan
