Backlight bleeding issue on QNIX 2710, what to do?
ttg_Avenged
545
Hello there, so I have had a QNIX for about a year now. Luckily there wasn't much backlight bleeding, and I took a picture.
This is BEFORE I did absolutely any work on the monitor.
This is after I took out 4 Philips screws, and loosened a few of the tabs on the left, and bottom right. It got worse. I did NOT take off the entire bezzle.
So I immediately stopped, halfway through taking off our popping the clips connecting the front bezzle. Should I continue? It got worse.
The bezzle clips are here:
By the way, please ignore the white mark in the middle right of the monitor, stupid niece threw a screwdriver at my new screen.
why were you trying to take the bezel off? i would stop cause you have probably damaged the display in the process, the backlight bleed looks awful, and the screwdriver mark, i would have gotten rid of the product a while ago, especially with that degree of damage anyway, if its fukt its fukt, nothing you can do about it, i would have sent it back because of the backlight issue when you got it, i personally have a little bit on my lcd but that is a whole other level, there is not much you can do though, shift it to somebody on ebay or put it in a landfill cause there is no way you can fix it, see if re attatching the bezel can do anything for you :)
Lol, if you don't know the product that's fine but this Korean 200$ 1440p 96-110hz monitor (yes, 200$) is a bargain after you fix the Blight bleed. PLS panel, too. Amazing monitor, bad bleed. Bleeding if fixable, I just don't know how to fix it.
I read online loosening the bezel fixes the bleeding.
doing that can actually cause more of a problem as it allows more light to escape, re attatch the bezel or try the duct tape method that you can look up online, its a bit risky though 😀
