Hi,
I'm noticing some problems with fitting the Artic Freezer Pro 7 on my Intel Bad Axe 2 motherboard and was hoping to get some advice. When installed as suggested with the air blowing towards the rear exhaust fan the chipset heatsink is interferring with the 92mm fan clip. I can push it in which pushes the heatsink plastic just a very tiny amt though and everything is attached. It is touching though but when I push down on either the chipset heatsink or the freezer pro both seem to be able to move and slide.
I'm not sure if that's safe to do since I don't want to hurt the thermal contact with the chipset heatsink and I want to make sure the freezer pro is totally touching the CPU. The one solution I've found so far is that the 92mm fan they give you with the freezer can practiclly clip anywhere on the heatshink. So if I clip the fan just one fin higher it fit's perfectly fine. The only problem is that the bottom most fin won't get any air coming from the fan.
I've attached a picture of it touching to take a look at so you can get a better idea of what I mean. Any ideas? Is it safe just to connect the freezer pro 7 fan up one fin and have everything fit fine? Should I just leave it as is with it touching?
Thanks in advance! (Picture is below)
