Bad LED LCD?
cheeto2
43
Is this a bad display? The screen doesn't have a crack anywhere. I do get a signal from the HDMI port, but I can't get into the BIOS or do a system restore since the HDMI does not send a signal until windows drivers are loaded. Appreciate any help/suggestions.
Thanks for the response, but this is one of those Intel Atom/built-in hard drive systems (HP Stream) and the GPU cannot be tested independently. I do get a good signal from the HDMI port with the limitations already mentioned. Unplugged screen cable at both ends and plugged back in a few times... no luck unfortunately.
