So this is sort of a strange thing. I've just upgraded the cooler in my PC to a be quiet! Dark rock 3 pro. I had a little Zalman CNPS10X OPTIMA on there for about a year and it always ran kinda warm with the I7 6700k (stock clock). Under a prime95 test (Max heat) it would run well into the 80s and touch 90° from time to time. I would expect the much larger dark rock 3 to perform much better but it tops out at 85°. similar systems barely break 70 overclocked. That being said the thing is a bear to install into a mid tower and I might have smeared the thermal paste to got a bubble under it, which is the main question. Should I remount the monster or is this an expected result?
Note: stock core voltages were 1.36 volts which is kinda dumb but for the sake of consistency I left it for the new cooler because that's what the old one was tested at. Dropping it to 1.2 chopped near 15°.
