So this is the story
I am running a 5960X oced to 4.5ghz on the rampage v extreme full specs in signature) and before 3 days i was editing a family 4k video of an hour in adobe photoshop and as it was reducing the quality to 1080p i saw that there the time showed about 30mins and then suddenly the time showed to be 1.5hours did it again and after 8 mins the half an hour turned to 1.5 hour. Igot it that something was wrong and opened task manager i found that the cpu was at 100% and also it was at 4.5 ghz so i felt nothing abnormal there and so now i opened speedfan for temps anf the temp was 96c and i just freaked out. I thought that i recently might had chsnged the thermal paste from a cheap one to the evga frostbite and must not thightened the water cooler properly so while comp was running i slowly opened the case and felt the heat inside (btw the gpu was at 75c) and found that the cooler was not tightened i immidiately thightened the screw and there was still no change i turned off everyapp and went to task mgr and speed fan both showed like 2 to 6 percent cpu usage and temps came down to 70c and then no temp going down i turned off the computer and cleaned the thermal paste cleaned tge cooler and again applied the thermal paste but no change.in the bios i reset everything and now the idle temp is 62c. I yesterday was playing bf4 with my friend online and suddenly my computer turned off i almost went numb??and after turning all power and everthing and turning them back on my computer did not turn on!!!!!!!!!!!! I tried all sorts of things but none of them worked and also i even changed ghe psu but it just wont turn on i am writing this on my ipad and really depressed. The computer is just 4 months old. ????
PLEASE HELP PLEASE!!!!!!!!!!!!!!
