Banding on high speed, not on hi quality
DaveC
204
Archived from groups: comp.periphs.printers (More info?)
Epson SC900. I get vertical banding (bands that run horizontal) on the black
and yellow inks when printing high speed (bidirectional), but not when
printing high-quality (unidirectional).
The yellow has a little black that makes up the bands, while the black simply
varies in density.
Why would this be? I've cleaned the bottom of the head, the head "park" pad,
and run cleaning fluid through the head. None seems to help.
Ideas?
Thanks,
Please, no "Go Google this" replies. I wouldn't
ask a question here if I hadn't done that already.
DaveC
me@privacy.net
This is an invalid return address
Please reply in the news group
How did you clean the head bottom. It often has a LOT of dried ink on
it, and a partial cleaning may not be adequate to remove all the dry ink
which can cause nozzle deflection.
Also, do an alignment, sometimes stuff that shows up in bi-directional
head movement that doesn't in uni is due to alignment being out.
Make sure the head wiper is clean (next to the cleaning station). Be
gentle when cleaning the underside of the head to avoid misaligning the
heads. Make sure you use a lint free paper towel and no residue from it
has been left behind.
Last step, if nothing else works, you may need to run some cleaning
cartridges, as you may have a partial internal clog in one of more
nozzle. This is simple to do with the SC900 because it is unchipped and
uses the simple to refill cartridges.
Art
> varies in density.
> Ideas?
> Thanks,
On Fri, 4 Feb 2005 04:18:15 -0800, Arthur Entlich wrote
(in article <bKJMd.3295$rB6.2084@edtnps91>):
> Art
>> black
>> simply
>> varies in density.
>> pad,
>> Ideas?
>> Thanks,
I've done the "towel under the head saturated with Windex/alcohol" technique.
I let the head sit on this towel overnight. No improvement.
I've aligned the head many times.
The wiper seems to be clean.
Have cleaning cartridges; will run these as a last resort.
A Question: if the nozzle test print shows all nozzles firing, then doesn't
this prove that the nozzles are healthy and aren't clogged? How can cleaning
them out more improve the banding problem?
Thanks,
DaveC
me@privacy.net
Sometimes, nozzles are deflected slightly. If you look at the nozzle
check very closely, you may see the steps are uneven or out of sequence
in location. Sometimes the nozzle is clogged enough that the ink is
delayed in getting out.
Sometimes there is just enough obstruction that the amount of ink
getting out is not the full amount, so the ink line is thinner or
mispositioned.
Very occasionally, paper transport problems can lead to banding (the
gears may be worn, the stepper motor not driving the gears or other
parts correctly. Paper slippage due to glazed platen or other parts can
also occur.
Most often the problem is the heads, however.
Art
> Thanks,
