[SOLVED] Bandwidth on PC way slower then it is supposed to be, (Solved)
I had this problem last time I refreshed this P.C. and remembered I had the problem but did not remember what was the fix so I am posting this because I could not find the answer anywhere either time.
So if you have done speed test and on one device it gives the correct bandwidth, but on the PC it the speed is way slower then its supposed to be.
Solution: I was using Opera for a Browser and it has its own VPN, I had it on as well as a paid VPN.
You only can run one. this fixed my issue.
Note! Make sure you only run one Firewall or Virus protector.
