barton 2500 wit Aero 7+ heat issue
FunkySmile
7
ASUS A7N8X Dlx Rev 2.0 Bios 1003 (nice eh?)
Barton 2500+ 1992MHz (166*12)
Coolermaster Aero 7+ (using Artric Silver 3)
CRAP old case (from a TIME computer purch Jan 2000) tsk, tsk, tsk
problem is... In idle temp 50C Aero running on full power (3650 RPM) not good and so loud, load (closed box) up to 58C (even worse), open box 55C. MB temp ok at 33-38C, (can live with that)
These temps are obviously not ok at all, any1 be able to help me with this PLEASE?!? I dont know what to do
Well you should've asked these forums before you bought the cooler, since the the SLK800U is soooo much better compare to the Aero7+.
-Intel PIV 2.4C @ 3.84G -Asus P4P800 -OCZ Gold 2x256 3700EL memory @ 256mhz 2.5-3-3-7 -Sapphire 9800pro @ 490/780 -SB audigy -80G Maxtor Diamond Plus9 Ultra ATA-133 hdd -450 Enermax PSU
