bascially i increase my gpu fan speed to 60
terminator123
830
percent
is that oaky
it started to happen once i installed my gtx 660. into my new pc
as when playing arma 3 sometimes my game was just freeze,e verything would suddnely go slow
ive checked HDD and its upposed to be okay
ive chcked ram.. supposed to be okay
people said it could hav ebeen y gpu or overheating
my temps for gpu are 60-70 now and im waiting to see if it happens again
usually when it happens my whole pc freezes and i have to restart it
i kept rollbacking and updating drivers because sometimes it would come at the bottom rigth corner say kernel driver or something
is 60 percent gpu speed safe?
ill let you know if issue happens again.
and i keep getting this issue
Arma 3
D3D Error - DXGI_ERROR_DEVICE_REMOVED
OK
nope but idk it keeps happening and i get that d3d error
but also
im a bit worried as when i installed my gpu i heard quite a loudish click
and i hope it didint snap my motherbaord
i didint exactly give loads of force on it but
idk is it meant ot make this noise.
i hope it didint snap my board heatsink orsomethiong.
oh right okay then
also is it okay if i increase my gpu fan speed to 60 percent if that was rthe problem
i also updated my onbaord intel hd 4600 driver
maybe supposed to fix this (even tho im using gtx 660)
kay then but sometimes it crashes my whole pc! and it freezes and arma goes competely slow and my pc stops working! then i have to restart?
How did you uninstall your drivers?
earleir on i uninstalled nvida i guess and reinstalled and updated
as with intel i just disabled it like the guy said above,
im seeing if it will happen
but ill guarentee that my pc will freeze again while playing arma 3 and ill have to restart, by pressing restarting button on pc.
Use DDU. Follow the instructions on the download page. If your old drivers are still there or something didn't uninstall correctly, the old drivers could be conflicting with your current drivers.
Also, what CPU do you have?
okay but which ones shall i unstil
and intel core i7 4970k running at 4ghz and 40-50 temps on arma 3
Those temps are normal. I recommend uninstalling all NVIDIA drivers. After that is done, reinstall the newest drivers for your GPU.
hm okay ill try it but when it happens why does it crash my whole pc? its freaky
