Base System Device driver missing HP Elitebook 6930p with Win 7
Kmsoars
9
I have been to the HP website and searched for this driver, but it will not show specifics to this model laptop. Troubleshoot keeps showing it is missing. I am also missing the PCI Simple Comms Controller and the PCI Serial Port. Any suggestions how I can fix this problem? Thanks!
What about the PCI serial port driver and the PCI Controller? Will that have any effect? I am trying to backup to a new WD Passport and keep having failures. Seems to be timing out because of the USB 2 to USB 3. Was wondering if the PCI missing drivers would contribute to this problem. Thanks!
Downloading the chipset from HP took care of the PCI issues, but not the base system device driver one. I have a fingerpad and it works despite the error, so will disregard. It is an older laptop and I guess that driver is not supported anymore.
As for the WD Passport I can see it in my devices list and can save data files to it. It just won't backup to it. I am not sure what PNP IDs are so if you can explain that would help. I have not tried to backup again since adding the chipsets.
Love this site. Thank you all for your help!!!
