Based of these specs, Should I get Liquid Cooling?
Dispacho
AZZA ATLAS CASE BOM GAMING CHASSIS
ASRock Z87 PRO3 Motherboard and Intel Core i7-4770K 3.5GHz
G.SKILL Ripjaws X Series 16GB DDR3 1333 (PC3 10600) Desktop Memory
GENERIC 1TB HDD + 240GB SSD Internal Hard Drive
AMD Radeon R9 290X 4GB Video Card with 850 Watts Power Supply
Generic Blu-Ray Disc Combo Drive
Microsoft Windows 8.1 Pro - 64-bit - OEM
by liquid cooling, you mean a small all in one kit like the ones by nzxt and corsair. Or do you mean custom liquid setup? Closed loops are worth it if you get a dual fan like h100/110/105, especially if you have a window on the side of your case as it looks nicer than a huge air cooler. But $100 spend on all in one vs air cooler of same price, cooling is pretty much identical. Air coolers do move a lot of air across your motherboard cooling that as well though
