Mostly okay but not the best choices for SSD, mobo, RAM and PSU. Updated the build with my suggestions, cost went up $38.
- SSD is better for reliability and speed
http://ssd.userbenchmark.com/Compare/SanDisk-SSD-Plus-240GB-vs-Crucial-MX300-SATA-M2-275GB/m25612vsm159989
- With the Z170 mobo you will have either make sure that it comes with the F20 or greater BIOS version or you will have to find a Skylake CPU to put in the socket so you can update the BIOS. I swapped it out for a Z270 board which will be supported for sure and slightly better connectivity as well
- With the Z270 and k-processor you will want high speed RAM, chose a good 3200 MHz
- The NEX series PSU's are not good, a blip for EVGA (Tier 3). Replace with the Hydro G which is an excellent PSU (Tier 1).
http://www.tomshardware.com/forum/id-2547993/psu-tier-list.html
PCPartPicker part list:
https://pcpartpicker.com/list/qs3DKZ
Price breakdown by merchant: https://pcpartpicker.com/list/qs3DKZ/by_merchant/
CPU: Intel Core i5-7600K 3.8GHz Quad-Core Processor ($234.96 @ Amazon)
CPU Cooler: Enermax Liqmax II 240 96.0 CFM Liquid CPU Cooler ($64.99 @ Newegg)
Motherboard: ASRock Z270 Pro4 ATX LGA1151 Motherboard ($117.99 @ SuperBiiz)
Memory: Corsair Vengeance LPX 8GB (2 x 4GB) DDR4-3200 Memory ($79.99 @ Newegg)
Storage: Crucial MX300 275GB M.2-2280 Solid State Drive ($89.88 @ OutletPC)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive ($46.88 @ OutletPC)
Video Card: Gigabyte Radeon RX 480 8GB G1 Gaming Video Card ($239.00 @ Jet)
Case: Rosewill WolfAlloy ATX Mid Tower Case ($59.99 @ Newegg)
Power Supply: FSP Group Hydro G 650W 80+ Gold Certified Fully-Modular ATX Power Supply ($79.99 @ Newegg Marketplace)
Operating System: Microsoft Windows 7 Home Premium SP1 OEM 64-bit ($99.99 @ My Choice Software)
Total: $1113.66
Generated by PCPartPicker 2017-03-07 12:20 EST-0500
