Hey,
Just wanted some suggestions on what I should change in this very basic gaming build (I am only planning to play WOW, KOTOR 1 & 2, and maybe ES Oblivion. I will also do some 3D animation on this PC.
The reason I went with the tri-core 720, is because I really like the possibility of unlocking the fourth core..
and its a great processor.
And yes, I know combos are available for alot of these....including the mobo and processor. The reason I didn't use it is cause if the build is changed it gets confusing lol.
I was planning on sticking with biostar because of its great bios OCing layout...but I'm open to other fourth core unlockable mobos that have nicer built in graphics card.
Also, I was planning on building this and in the future upgrading the graphics card.
If I can lower costs in any ways...that would be great.
But I'm willing to invest another 50$-75$ for any component that really lacks power...and you think should be changed/upgraded.
THANKS
Case and 585Watt PSU
http://www.newegg.com/Product/Product.aspx?Item=N82E16811121004
G. Skill 1066 4GB Ram
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231241
XIGMATEK HDT-S1283 120mm Rifle CPU Cooler http://www.newegg.com/Product/Product.aspx?Item=N82E16835233003
Western Digital Caviar Black WD6401AALS 640GB 7200 RPM 32MB
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136319
AMD Phenom II X3 720 2.8GHz 3 x 512KB L2 Cache 6MB
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103649&Tpk=AMD%20Phenom%20II%20X3%20720%202.8GHz%20Socket%20AM3%2095W%20Triple-
BIOSTAR TFORCE TA790GX 128M AM3/AM2+/AM2 AMD 790GXhttp://www.newegg.com/Product/Product.aspx?Item=N82E16813138130&Tpk=BIOSTAR%20TFORCE%20TA790GX%20128M%20AM2%2b%2fAM2%20AMD%20790GX%20HDM
and its a great processor.And yes, I know combos are available for alot of these....including the mobo and processor. The reason I didn't use it is cause if the build is changed it gets confusing lol.
THANKS
