USAFRet :
One word: Radio
As mentioned above, there can be a LOT more interference, due to a lot of factors.
A Cat5e ethernet cable will give you gigabit speed out to 100 meters.
Now...take your laptop, standing right next to the router. You may get something approaching whatever magical advertising number is printed on the WiFi adapter box.
Now walk away, measuring your performance. The farther out you get, the slower it gets. Eventually, you get nothing.
Now add in a typical house. Rooms, walls, kitchen, other devices...who's cooking something in the microwave?
Interference. With that interference, the WiFi adapter and router have to resend the same bits several times. So the time to transmit something takes much longer.
I tried to Edit this post before the answers rolled in.
Does this change anything:
Hi
Can someone explain to me in simpleton terms why my wireless speed (LAN??) is not as fast as what the ISP's Internet Speed is rated at?
1) I have a Verizon Quantum Gateway router. [800 mbps]
2) My NIC Card is: Dell Wireless 1505 Draft 802.11n WLAN Mini-Card. [300mbps max]
3) I live in a multi-family dwelling. (channel sharing interference?)
4) Wirelessly I get approximately 80mbps Up & Down.
5) Wired directly with Ethernet Cable (can't be permanent option) = 100mbps- which is correct.
What to do?
Thank you
(also, I'm 10' away computer > Router, unobstructed)
