Question bass sound is high
Jul 9, 2020
5
resently i use EqualizerAPO64-1.2.1
to increase sensitivity of my headphone mic
but my headphone become noisy
i think my bass is high
i try to reinstall windows but nothing change
now i connect my headphone by monitor and every thing is fine
so how can i fix what is wrong with my sound
thanks
thanks
Analog phones ? When you connect them to monitor you are using digital sound to monitor thru HDMI/DP. When you connect them to MB (Back or front) it uses onboard CODEC chip and circuit for analog sound so you need drivers for it and then you should be able to adjust it with it's control panel.
