batman AC low fps on gtx 760
karelson
32
Hey all
I have a new card
Evga 760
4770k
8gb
I install batman AC.
Used all default settings to max settings. With phsyX off.
Went in side the game to settings and ran the in game build in FPS benchmark.
In all tests my max fps is 60 with 55 avg.
This is very low I think.
An I doing some thing wrong?
What do you think or suggest?
How can test my FPS?
Thank you.
Turn VSYNC off, because it can cap the FPS. If your monitor is only 60hz, then you are fine. If you want more performance, disable Anti-Aliasing (it is a big FPS killer, and can blur the image. Personally I don't like it anyways). You can try to overclock your 760 by 10%.
hmm i think is normal , wat setting , resolution u are playing ?
It might be your moniter, if it has a 60 hz refresh rate and vsync is on, itll cap you there. but that is great performance. on my OC'd 560 Ti i get 45-50 fps with everything maxed out
