Batman Arkham Origins Resolution Problem
adamdoom89
5
Batman Arkham Origins is unable to go above 1280x720
it seems to be the highest resolution available in the game settings.
My resolution is 1920x1080 on desktop and for all other games like Battlefield 4, Borderlands 2, Marvel Heroes, Tomb Raider etc.
What can I do to change the resolution to 1920x1080
I've already tried to go into the ini. and .xml files located in my Documents to change the resolution x and y but it keeps resetting back to1280x720 every time I start the game. Is there something more specific I should be doing? Maybe I'm not changing the properties properly?
My Specs are down below if that helps. I'm also running the latest Nvidia Drivers and when I use GeForce Experience to Optimize the Settings, I just get an Error message...
Any help would be much appreciated,
Here's my Specs,
Mini ITX HTPC
Cooler Master Elite 130
MSI GeForce GTX 760 OC
Intel Core i3 3225 CPU
Gigabyte GA H77N-WiFi Motherboard
G.Skill Ripjaws X (2x 4GB) = 8GB DDR3 1600
WD Blue 1TB HDD 7200RPM
Corsair CX500 PSU
Corsair AF120 Blue LED Quiet Edition
Cougar 120mm Fan
Here's some Screenshots
Yes I've done two clean installs... I had a R9 270 with the latest drivers from AMD... The same exact thing happens with this card too so I upgraded to the GeForce GTX 760 and now I'm using the latest Drivers from them and the same thing happens again... This is really frustrating because I want to enjoy the game in 1920 x 1080 resolution...
Yes three times... The game files from Steam were over 20GB and I even clicked the option to verify Integrity of game which didn't fix the problem... I'm hoping if someone else experienced this problem has a solution...
