B buldaroxsette Mar 16, 2018 11 0 10 Mar 16, 2018 #1 can you still open your laptop with built in battery even if it is damage(the battery) while the battery still inside the laptop?
Solution J J jarotech Mar 21, 2018 If the battery does not heat up, it will not damage anything on the motherboard, you can continue to use your laptop connected.
J jarotech Dignified Oct 13, 2012 3,927 2 16,960 Mar 18, 2018 #2 Hi, what do you mean open the laptop? Physically open the laptop or just start the laptop? Upvote 0 Downvote
J jarotech Dignified Oct 13, 2012 3,927 2 16,960 Mar 20, 2018 #4 Yes, you can start your laptop even if your battery is not good, what do you mean by your battery is damaged? Upvote 0 Downvote
B buldaroxsette Mar 16, 2018 11 0 10 Mar 21, 2018 #5 Overcharge or not charging, it is not going damage the other hardware right? Even if you continue using it while plugged in. Upvote 0 Downvote
J jarotech Dignified Oct 13, 2012 3,927 2 16,960 Mar 21, 2018 Solution #6 If the battery does not heat up, it will not damage anything on the motherboard, you can continue to use your laptop connected. Upvote 0 Downvote Solution
B buldaroxsette Mar 16, 2018 11 0 10 Mar 21, 2018 #7 thank you very for your response. Upvote 0 Downvote
J jarotech Dignified Oct 13, 2012 3,927 2 16,960 Mar 21, 2018 #8 You can always disconnect the battery if it does not charge. Upvote 0 Downvote
B buldaroxsette Mar 16, 2018 11 0 10 Mar 21, 2018 #9 Like removing it on the laptop? Upvote 0 Downvote
J jarotech Dignified Oct 13, 2012 3,927 2 16,960 Mar 21, 2018 #10 You can simply disconnect the connector from the motherboard or you can remove the battery from the laptop, it's up to you to decide. Upvote 0 Downvote
J jarotech Dignified Oct 13, 2012 3,927 2 16,960 Mar 22, 2018 #12 If you have more questions about your problem, just ask. Upvote 0 Downvote
B buldaroxsette Mar 16, 2018 11 0 10 Apr 3, 2018 #13 what to do when your laptop with built in battery won't turn off? Upvote 0 Downvote
J jarotech Dignified Oct 13, 2012 3,927 2 16,960 Apr 3, 2018 #14 How do you turn off your laptop, do you choose Shut down to turn off the laptop? Upvote 0 Downvote
J jarotech Dignified Oct 13, 2012 3,927 2 16,960 Apr 3, 2018 #16 But what happens after choosing the Shut down? By the way, the battery inside does not interfere with the operation of the laptop. Upvote 0 Downvote
B buldaroxsette Mar 16, 2018 11 0 10 Apr 3, 2018 #17 supposedly the light should turn off when you shut down but it didn't, the screen is in black already. Upvote 0 Downvote
J jarotech Dignified Oct 13, 2012 3,927 2 16,960 Apr 3, 2018 #18 OK, what is the make and model of your laptop? Upvote 0 Downvote
