Battery charging habits - How to properly charge the phone?
doriandiaconu
39
How do you guys charge your phone?
Do you respect the old 40-80 rule?
Just got the Xperia XZ1 Compact and don't want to screw up it's battery.
I sent a message and it seems I got an answer from the official support that said:
The battery will be damaged if you leave your device charging for a long time after reaching 100%. To keep this from happening and to extend the battery life, the latest Xperia™ devices have a built-in feature called Battery Care (currently Xperia™ X Compact, Xperia™ XZ, Xperia™ XZs, Xperia™ XZ Premium, Xperia™ XZ1 / Xperia™ XZ1 Compact). With other device models, avoid continuing to charge your device after it has reached 100%.
After that, I sent back a message to the support again asking about the lower limit and they sent me some link for the phone manual, lol. So I guess that's it for the help from the costumer support.
https://support.sonymobile.com/gb/xperiaxz1compact/userguide/battery-and-power-management/
Thanks!
Try to keep your phones battery between 20%-80% and avoid fully charging it.
I've also heard some people saying that you should sometimes fully drain the battery but only rarely.
in general now fast charge will damage your battery more than ANY kind of behavior :)
EXAMPLE: IF you charge:
2 A will last a year
1 A will last 3 years
0.7 will be ~5 years
with same charging behavior. IF you want your battery to last, switch for slower chargers (especially if you charge overnight) and avoid discharging battery under 15% if you still want to use QC
That hasn't been my experience - - I've been charging my Xperia SP phone with a 2A charger for four years, and my wife's been using a 2A charger for her iPhone 5 also for four/five years.
So your assertion that it "will last a year" just doesn't stack up.
Shouldn't ever take a Lithium Ion battery to 0%, ever. Repeated 0% will kill it. Only batteries that benefit from 0% drains are NiCad, to help remove any 'memory' the battery might attain. Other than that I've had my Galaxy S5 since it was new, it charges every night for 5-7 hrs, and gets charged in a work van on a 2.1A charger every day. No battery issues so far.
Quick charge tech pushed batteries A LOT quality changed massively and QC-charged batteries will be usable for years. 1 thing you does not nottice is LOWERED full change. When you will change your batter for new one it will hold +50% longer on same 100% charge.
1 year comparison was an example.
if your's handled 4 years well then, slower charger would add ~2 years of batter lifetime.
I had xperia z1 phone, it was last one when no QC existed, but CPU already had features supporting it.
battery survived 4 years without problems, still holding 1 day no-sweat. While I switched to QC, Battery shock was enough to kill it in a month.
Please compare discharge time (even estimated on something) and you will notice lower capacity, but how much lower, that depends how hard you use it. A lot of things does play a role here, temp while charging (like gaming and charging), quality of charger, quality of battery ....
Hi,
I've heard of the 20 80 rule. But I've grown up with NiCd and I'm a 0 100 man :).
It seems to suit me, my stuff works.
My Iphone battery is still at 99% after nearly a year.
