Battery drained !
passing-thru
56
Greetings,
I have a second-hand (from a friend) shoe box PC mobo which keep draining the battery (within 3 days).
Can't find any thing physical wrong with it. I mean, no shorts, no burn marks....
Need your advice.
The PC is AMS gBOX Blue with CFI-S96 mobo.
Thanks in advance.
Greetings,
Need your advice.
Thanks in advance.
Time for a new motherboard :). Mostly like the board is somehow damaged.
Yep; that sounds like a not so easy to solve problem if you can't see the problem at once. Does the battery get hot or even warm?
