Battery draining too quickly
Oct 10, 2018
Hello my laptop is a HP Pavilion 15000. I bought it brand new from Currys PC world less than a week ago and just recently over the past few days the battery has been draining extremely quickly (50%) within an hour) and the battery life is supposedly 10 hours. What should I do HP support says there is nothing new and all my devices have been updated.
Go look and see what you are allowing to run as a background process as well as apps running in the background. Turn off anything you don't have to keep on. Turn your screen brightness down as often that is a big cause. If you are doing anything intensive where you hear fans kicking up, you should probably be plugged in anyway.
Try running the energy saver settings.
