Battery not charging past 83%
Jun 14, 2018
So my laptop battery died while I was halfway through running a memtest (booted on a USB drive). After that, I plugged in the charger, and ran the test again. Everything seemed to be fine. But when I booted back into windows I found that the battery could not charge past 83%. I've looked up and tried many solutions but none of them worked. I ran tests on the battery and no problems were identified. It doesn't seem like a problem with the battery itself. Please help, thank you.
If I charged long enough it very slowly goes up to 89%, or 90%. But it's unstable, when it reaches those levels, it'll start discharging while plugged in. Basically it fluctuates around 80%~90%.
The problem went away by itself today, I'm now able to charge up to 100%. I didn't do anything other than letting it discharge until 30%-ish and back to 83% (where it stopped charging) for a few times.
