[SOLVED] battery replacement kindle fire 10
kiberniths
41
I have a kindle fire 10.1 tablet 2017 edition and i want to replace the battery. Is there an original battery replacement for it or i must search on third parties batteries? and if i search to the third parties battery replacement can i use a bigger battery for it?
i cant find the exact type of the battery of that tablet, in other tablets you can see clearly which battery to choose.but in this tablet it show batteries from third parties companies and i am wondering if they are normal bateries or some chinese replicas
Amazon doesn't sell replacement batteries or share their sources for their batteries. You may try to check with a local cell phone repair shop to see if they have any suggestions. If your device is within a year of purchase (unlikely as it is getting close to the end of 2018) then it would still be under warranty (HD 10s have 1 year warranty, all others have 90 days.) If the battery goes bad within the warranty period, it would be worth it to contact Amazon Kindle tech support (htts://www.amazon.com/contact-us) At the very least, you may be eligible for some type of out of warranty offer.
