Battery Status Icon missing in systray
David
2,039
Archived from groups: microsoft.public.win98.gen_discussion (More info?)
I noticed last night, when my laptop suddenly dropped dead from no
battery power, that the battery status icon is missing from the system
tray. How do I put it back? I'm running Win98SE with the latest 'n
greatest updates from Microsoft.
Thanks,
David
That program isn't MS, I don't think. It's proprietary from the maker of
the laptop. You're going to have to find out where the settings for that
are and re-set the "Icon in Tray" item. You'll probably find it in
Control Panel.
One thing to check first---have you used MSCONFIG to disable any items
from the Startup processes? If so, perhaps you simply disabled the
battery monitor there.
Gary S. Terhune
MS MVP Shell/User
http://www.grystmill.com/articles/cleanboot.htm
http://www.grystmill.com/articles/security.htm
"David" <david.henderson@comcast.net> wrote in message
news:1121128674.901247.228170@o13g2000cwo.googlegroups.com...
> Thanks,
> David
Start> Settings> Control panel> Power Management> Advanced tab:
put a check in the box to 'show the icon on the taskbar', and click OK.
Glen Ventura, MS MVP Shell/User, A+
http://dts-l.org/goodpost.htm
> Thanks,
> David
Really? That also handles battery monitoring? (As you can tell, I don't
work on many laptops, <s>.)
Gary S. Terhune
MS MVP Shell/User
"glee" <glee29@spamindspring.com> wrote in message
news:u99p05nhFHA.3316@TK2MSFTNGP14.phx.gbl...
> OK.
>> system
>> Thanks,
>> David
Well, it did on all Win95 since the Gold version, and the control panel applet is
basically the same in 98, so I would assume so....don't have any Win98 laptops
around. AFAIR, WinXP does the same.
"Gary S. Terhune" <grystnews@mvps.org> wrote in message
news:%23fPewAohFHA.3652@TK2MSFTNGP10.phx.gbl...
> Gary S. Terhune
> MS MVP Shell/User
> > OK.
> >> system
> >> Thanks,
> >> David
Yes it does. Yet as you mentioned, the manufacturer may install there own PM
util. If they do and you try to open either Power Options or Display > Screen
Saver > Power, a popup should display directing you to use the manufacturers
installed utility which should also be located in Control Panel.
Brian A. Sesko
{ MS MVP_Shell/User }
Conflicts start where information lacks.
http://www.dts-l.org/goodpost.htm
http://basconotw.mvps.org/
> Really? That also handles battery monitoring? (As you can tell, I don't work
> Gary S. Terhune
> MS MVP Shell/User
>>> Thanks,
>>> David
Got ya. Makes all kinds of sense. Now that you detail it, I can vaguely
recall that stuff appearing in PM on a few systems I've seen.
Gary S. Terhune
MS MVP Shell/User
"Brian A." <gonefish'n@afarawaylake> wrote in message
news:Oy68zAphFHA.1252@TK2MSFTNGP09.phx.gbl...
> own PM util. If they do and you try to open either Power Options or
> Display > Screen Saver > Power, a popup should display directing you
> to use the manufacturers installed utility which should also be
