While installing the game in 64 bit i am getting the following error:
the program cannot start because MSVCP100.dll is missing from your computer.
Try reinstalling the program to fix this problem.
My config is as :
My configutration is as followes :
AMD athlon II X2270 Processor 3.40 Ghz
4GB ram
32bit
OS: windows 7 ultimate
and i was getting the following error while installing in 32 bit windows version :
The version of this file is not compatilbe with the windows you are running.check your computer information to see whether you need a 32 or 64 bit version of the program and then contact the software pulisher.
Please tell me how to solve the issue in 64 bit and can install the game on 32 it or not
My config is as :
4GB ram
32bit
