I haven't played BF in about 2 months. I recently decided I was going to play some again. I had to update the game and my GPU drivers to the current version. Now, I am getting a lower overall FPS, and tons of lag spikes, on all settings. These lag spikes cause me to die in the game, like crashing a heli. I have never had this issue before, as my computer can handle the game fine.
I had a CPU monitor next to my screen, while playing bf4. Each time I would get a lag spike, the CPU would go down from 80-90% to 30-40% then right back up.
I rolled back my GPU drivers to Catalyst 14.4 from 14.9, that didn't help. I've used Advance System Care 7 to fix up my computer, didn't fix the lag spikes, and freezing. I tried to fix the game through Origin, and that didn't help. I use to be able to run BF4 on ultra (no AA) with a steady 40 fps, with NO lag spikes, at all. Now, its just horrible, its like not even playable. Every 10-20 seconds, I will get a 1-2 second long freeze. Sometimes, the game just freezes all together, and then I will be kicked from the game. Not sure if that has to do with internet or not. I usually get 60-75 ping when I'm playing, and when the spikes hit, my ping doesn't change.
System:
Upgraded Asus Essentio CG5275
Intel Core i5-650 3.2Ghz Dual-Core
Asus P7H55-M Motherboard
SanMax 8GB 1333Mhz 4x2GB
Seagate Barracuda 1TB 7200RPM Sata
Asus Radeon HD 7790 1GB DirectCU II
EVGA 500B 80+ Bronze Certified Power Supply
Windows 7
1440x900 Res monitor
Please help. This is annoying me to death.
System:
Windows 7
