BATTLEFIELD 3 - Performance problem with ASUS GeForce GTX 660 Ti
Epsilons
7
Ok here is my Rig :
CPU : Intel Core 2 Duo E6700 @ 2,66Ghz but Overcloacked at 3,2Ghz (2 cores)
Memory : 4GB DDR2 Patriot (2x2GB)
Video card : (BRAND NEW) ASUS GeForce GTX 660 Ti 2GB GDDR5 192bit with latest drivers installed (305.68)
Power Supply : (BRAND NEW) Thermaltake TR2 @ 600W
MotherBoard : ASUS P5L-MX (PCI-E 16x)
Running on Windows 7 x64 Ultimate
I'm running BF3.exe with a resolution of 1280x768
All settings on LOW
And i'm getting 10-15 FPS ?
WHAT THE *** ?
I was getting like 30+ FPS with a 6 years old GeForce 8800GT...
Is it possible that because of my PowerSupply (Thermaltake TR2 600Watt) having a 12V rail of only 22amp, and NVIDIA recommend minimum a 30amp 12V rail for the GTX 660Ti that my Video card cannot perform as it best?
Ok now i have try the SINGLE PLAYER Campaign of BF3 and i'm getting around 50-60FPS all Setting ULTRA and 1680x1050, but in Multiplayer i can't had more then 10-15FPS... where's the problem with Multiplayer ?
The problems your CPU. Battlefield 3 multiplayer kills a dual core. You'll need a quad core at least to make things smooth. If you're strapped for cash a Q6600 can be found for £60 on ebay and that'll make things smoother.
CAN I PLAY BATTLEFIELD3 WITH grafic card:
MSI r7770
PROCesor:
Pentium Dual Core G620 Box (2.60GHz,2C,FSB 1066MHz,65W,32nm-Sandy Bridge,3MB cache,VGA 850MHz,s1155)
4GB DDR3 1333MHz
RAM:
4GB DDR3 1333MHz
PLEASE HELP ME !!!!
