Battlefield 3 randomly freezing my PC
lostitz0r
24
Since the december patch I've had troubles playing BF3 on my PC. Once every 20 minutes or so, my PC randomly freezes and the only thing I can do is restarting it.
For long I was just ok with playing other games like Diablo, MW3 and LoL, but I really want this issue solved now, especially when I'm looking to upgrade some of my components.
Specs:
- PSU: Enermax Galaxy DXX 850W
- CPU: Intel Core 2 Duo E7300 @ 2.66Ghz (http://ark.intel.com/products/36463/Intel-Core2-Duo-Processor-E7300-(3M-Cache-2_66-GHz-1066-MHz-FSB))
- GPU: Sapphire Radeon HD 5670 1GDDR5 (http://www.sapphiretech.com/presentation/product/?cid=1&gid=3&sgid=915&pid=310&psn=&lid=1&leg=0#)
- RAM: 4Gb DDR2, haven't checked manufacturer or anything like that
I haven't OC'd any components, only basic driver OC'ing.
At first I thought the problem might've been my CPU/GPU temp getting too high, but after testing it a couple of times my GPU goes to 50°C and my CPU goes to 56°C.
Can anyone help me having a chance at playing this awesome game again 🙁?
Your specs are pretty good except for the the cpu, i think you should upgrade it to an intel core i5 sandy or ivy bridge but that would require that you upgrade your motherboard to :sweat: the other components are fine :)
The memory is ok, I've checked it with memtest and it didn't give any errors.
I also forgot to put the mobo in my specs: ASUS P5QL PRO.
Any further help?
I have ran these two together and got a max CPU temp of 58°C and a max GPU temp of 55°C.
I have left it on for more than half an hour now, it didn't crash and the max temperatures were only 2°C higher.
Maybe it could be an Origin or BF3 problem, I'll try reinstalling both.
That'd be frustrating, but if I have to...
I've also noticed that I very rarely (maybe once every 1-2 months) get a random BSOD.
Well, I think it's random...
I have the same issue. It locks up compleately after about 20 minutes.
Specs: 16GB PNY Optima RAM (1066)
AMD Phenom II x6 1090T
NVidia GTX 560
Asus M5A99X MOBO
Corsair H100 cooler (push-pull)
NZXT Phantom Case
OCZ X-Streme 600Watt
Windows 8 (had no problems with 7 but did the switch anyway)
PS: I'm running Nvidia driver 314.22... I'll try updating to a beta and see if that does the trick... its too much of a memory leak for 16gb...
Well i have same problem i play in game for a 5-10 min but then just freeze i have to restart the game the sound is like target target target target target target and
then i have to open task maneger and close it
plentium dual core CPU
ram: 4 gb
64 bit
windows 7
when u will solve the problem type on my skype Timai Šerbec or facebook same
