C cfranktps Honorable Aug 8, 2014 35 0 10,530 Oct 24, 2014 #1 I am stuck in battlelog on battlefield 4 and 3 for some odd reason. It says loading game but it really is not. I did not do anything that would make it do this.
Solution azzazel_99 Oct 24, 2014 Check the bottom of your screen. Usually says that but then if u check ur task bar at the bottom the game is open you just have to bring it up.
azzazel_99 Splendid Apr 19, 2008 4,015 0 23,460 Oct 24, 2014 Solution #2 Check the bottom of your screen. Usually says that but then if u check ur task bar at the bottom the game is open you just have to bring it up. Upvote 0 Downvote Solution
C cfranktps Honorable Aug 8, 2014 35 0 10,530 Oct 24, 2014 #4 no it still does not work the game does not even show it says loading game but does not show the game at the bottom Upvote 0 Downvote
ImDaBaron Admirable May 26, 2014 1,866 0 6,160 Oct 24, 2014 #5 Can we have your system specs please? Upvote 0 Downvote
C cfranktps Honorable Aug 8, 2014 35 0 10,530 Oct 24, 2014 #6 I fixed it i just re installed the battlelog plugin Upvote 0 Downvote
