Battlefield 4 Max Settings (Ultra with 200% Resolution Scale)
waterbadal
6
Hey guys! So recently I have made a gaming rig and I wanted to upgrade some parts so I can run Battlefield 4 on Ultra settings with 200% resolution scale with about 85+ FPS. So here are my specs so far, I am pretty sure my CPU is very good and now I just need to upgrade my GPU. I was thinking of buying a 7970, 7990, R9 280X, or a R9 290.
PC Specs:
CPU: AMD FX-8350 4.0GHz 8-Core Processor
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler
MoBo: Gigabyte GA-990FXA-UD3 ATX AM3+ Motherboard
Memory: G.Skill Ripjaws X Series 8GB (2 x 4GB) DDR3-1866 Memory
Graphics Card: XFX Radeon R7 260X 2GB Core Edition Video Card
Case: BitFenix Shinobi Window ATX Mid Tower Case
PSU: Corsair CX 500W 80+ Bronze Certified Semi-Modular ATX Power Supply
Now all I need from you guys is what I should upgrade, especially the graphics card, and should I need crossfire? Also is the CPU good enough or will it bottleneck the Graphics? And keep in mind I want a stable 85+ FPS.
Thanks guys!
You cannot get 85+fps on bf4 ultra settings with 200 % resolution scale with 8350 .Ihave that cpu along with an sapphire r9 280x and it gets me 18-23 fps on ultra with 200 % settings.but if u want that than you should go for 4 way crossfire r9 290x or an r9 295x2
.but seeing your budget i would recommend you an r9 290 asit would give u around 28-34 fps
I recently bought a MSI R9 280x, was getting around 20-30fps with everything maxed and up-scale. Then i dropped in a 7970 i found for £95 on ebay to crossfire and now i get 60-80fps! overall it cost me around £350 for the gpus, i belive thats like $500. Blows my friends R9 290x out of the water in all games iv played.
