Battlefield 4 Shadowplay rendering help?
Gregory Santana
68
well ive started to capture my gameplays on bf4 with shadow play but after video is completed the file size is huge so i tried rendering o upload to youtube example
https://www.youtube.com/watch?v=xBR4IeO_4Cg
but quality is not as good as others ive seen i play at ultra settings all other settings at max and recording is smooth but quality after rendering ok but after upload is not as good any tips anyone can give me would be awesome the videos come out great in 1080p 60+fps ingame its at about 135 fps no issues but file size is large but to upload to youtube it takes to long so i need to use a decoder/render it to youtube standards for fast upload but then quality goes down
MY RIG
Fx-8350 4.5 OC
Gigabyte g1 gtx 970
16gb ram
3tb 7200 rpm
1tb 7200 rpm
sofware
shadowplay
sony vegas pro 13
ANY TIPS WOULD BE APPRECIATED
It's quality is worse than software tools because Shadowplay uses on the fly hardware compression, which trades quality for convenience and speed.
If you want the convenience of Shadowplay AND are upset by both quality and file size, there's not much you can do.
Even at the max quality setting, Shadowplay isn't going to be as good visually as a decent software tool, but the file size should be smaller.
File size and speed are always the determining factors of image quality. You really can't get around that.
