Question Battleye false positive (It blocks pluckeye a program for self control)
jimhoxh1
54
Unfortunately battleye doesnt let me play fortnite because it blocks pluckeye, this program lets me block pornographics sites and other stuff,so i dont want to uninstall it. I contacted the support team but no response.Is there a way to hide pluckeye so the battleye cant find it and block it?
22:05:50: Starting BattlEye Service...
22:05:56: Launching game...
22:06:08: Note: File blocks can be ignored if they don't cause problems with the game.
22:06:08: [INFO] Blocked loading of file: "C:\Windows\System32\pluckeye.dll".
What happens if you just "quit/exit" the one program while you game?
If it is blocking it, what difference does that make to the game process and does it stop blocking it when you quit playing?
I am not sure why you would need a nanny program running while busy in a game.
I forgot to say that my problem is that i cant play the game,battleye thinks that pluckeye is a hacking program so it blocks it and doesnt leg me log in the game.
I am not sure there would be anything to do aside from uninstalling and cleaning the registry of it. Even at deleting it, I am not sure whether Battleye is going to act the same way.
IDK if you realize, but you can set your internet filters up to block adult content. You may also be able to set sites you wish to block within your router.
