Be Quiet Dark Base 700 - RGB not working
maurice.meli
Hi Guys,
I just built a new pc in a Be Quiet Dark Base 700. I am having an issue with the case rgb as it is stuck on white. Pressing the rgb button on the front of the case does not change the colour of the rgb lights.
Does anybody have a solution for this?
If you didn't connect the PCB cable to the RGB LED controller of your motherboard, then the switch should work as described in the manual. Contact be quiet! if it doesn't work.
