Be quiet dark rock pro 3 compatibility
dinomaster77.jw
31
I'm looking to buy a be quiet dark rock pro 3, I don't know if my ram and case are compatible I'd hate to buy it and have compatibility issues. The case I have now is a corsair 450d and ram is vengeance lpx, I know I can go water cooling and have no problems with compatibility but I like reliability of air cooling.
What are you system specs? https://www.ccleaner.com/speccy will tell you all the details about your system, motherboard, CPU, RAM. The be quiet! - Dark Rock Pro 3 67.8 CFM Fluid Dynamic Bearing CPU Cooler may require a separately available mounting adapter for Ryzen motherboards.
It will likely fit in that case.
CASE DIMENSIONS
19.45" x 8.27" x 19.57"
Dark Rock Pro 3
HEIGHT
6.42" (163mm)
There is clearance.
CASE DIMENSIONS
Dark Rock Pro 3
HEIGHT
6.42" (163mm)
There is clearance.
