Be quiet! Dark Rock pro 3???
kenchu
73
Hello guys.
If I buy the Be quiet!'s Dark Rock Pro 3 cpu cooler, will I be able to use both of its fans for my case?
I want to do passive cooling inside Corsair 400q mid tower.
I was planning on using both of those fans as intakes at the front. And one antec truequiet as an exhaust.
One of the cpu cooler's fan is 120mm, the other is 135mm. I am not sure if the 135mm fan will be compatible with my case. Any experiencie of you putting the same cooler in 120/140 mounting spots? Thank you
The front fan mounts for the 400q are 140mm (1x 140mm included). If you can somehow fix the two fans down without any movement then it should be fine. But I don't know how or why you would even bother doing this.
Fans are very cheap and can be purchased separate.
Just note that the cables from the fans that are for power and control will be very short and you would need an extension or splitter of some sort.
Update: Forgot to mention that the 400q is compatible with a 120mm at the front.
http://www.corsair.com/en-us/carbide-series-quiet-400q-compact-mid-tower-case
I want to keep it as cheap as possible. Plus, the silence.
Be quiet dark rock fans as intakes
Antec truequiet 120mm exhaust
Is it more silent than
2x antec truequiet 120 intakes
Antec truequiet 120 exhaust
Antec truequiet 140mm is not available in my country. I don't have a credit card to buy it overseas.
what kind of CPU are you trying to cool passively?
because that's... not that easy tbh
furthermore I don't really see the benefit
BeQuiet Silent Wings > Antec TrueQuiet (which aren truely that quiet tbf)
both aren't known for neither their high airflow nor their good pressure.
