Building a new PC, with a RTX 5090 and a Ryzen 9800x3d inside this Be Quiet PURE BASE 501 Airflow case.
The cooling setup is gonna be - Scythe Kaze Flex 120mm x3 at the front for intake, Noctua NH-D15 G2 LBC, and Noctua 140mm NF-A14X25R G2 at the back for exhaust. As you can see, the top of the case isn't solid, it's a removable dust filter made of plastic. I'm thinking about putting one of the stock fans on top right above the cpu but not sure if I really should do it and if I do, should it be exhaust or intake. What do y'all think? Thanks in advance!
