Hi guys.
Yesterday I was trying to exchange box cooler provided by Intel with a be quiet! Pure Rock Slim
https://www.bequiet.com/en/cpucooler/688
The cooler has a standard clip mounting included, similar with:
http://www.scythe-eu.com/uploads/tx_cfamooflow/4way-775_01.jpg
I was unable to do that because the motherboard was bending when I was trying to clip the cooler. After frustrating hours of work I disassembled whole PC and discovered that it is impossible to mount the cooler without breaking the board. I unscrewed cooler mounting and clipped it without a radiator to the board and then put the radiator on a CPU to see if it fits the mounting. Unfortunately there is a 2-3mm difference between CPU surface and cooler mounting level.
pic rel
The radiator is placed on a CPU but it does not touch the mounting on both sides.
My motherboard is Gigabyte GA-Z97-HD3 LGA1150 and is listed as compatible with the cooler on a be quiet! webpage. The CPU is Xeon E1231v3.
I am pretty damn frustrated and confused at the moment. Am I missing something obvious? There are no spare parts in the cooler box. There is nothing in the motherboard box which could help. I ended up with reassembling everything with a box cooler without a bit of a problem.
pic rel
